Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Disconnect the fan cable from the motherboard. Disconnect the fan cable from the motherboard.
    • Disconnect the fan cable from the motherboard.
  3. On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan. Once the fan is released, lift it straight up and out of the case. Once the fan is released, lift it straight up and out of the case.
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
  4. Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM. Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
  5. Disconnect the ATX power cable to the motherboard. Disconnect the P4 12V(4x2) power cable from the motherboard.
    • Disconnect the ATX power cable to the motherboard.
    • Disconnect the P4 12V(4x2) power cable from the motherboard.
  6. Disconnect the front panel ribbon cable by gently pulling it straight up. Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard. Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
    • Disconnect the front panel ribbon cable by gently pulling it straight up.
    • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
    • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  7. Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard. Disconnect the  optical drive audio cable connector from the motherboard.
    • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
    • Disconnect the optical drive audio cable connector from the motherboard.
    • Disconnect the audio input/output cable from the motherboard.
  8. Lift the metal tab near the right corner of the motherboard. Pull the green tab toward the front of the PC to release the motherboard.
    • Lift the metal tab near the right corner of the motherboard.
    • Pull the green tab toward the front of the PC to release the motherboard.
    • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
  9. Stand the motherboard up as shown. Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off.. Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
    • Stand the motherboard up as shown.
    • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
  10. Remove the screw at the rear of the motherboard. Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base. If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
    • Remove the screw at the rear of the motherboard.
    • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
    • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
Conclusão
14 outras pessoas concluíram este guia.
Kevin Schapansky
Membro desde: 05-10-2010
1.343 Reputation
9 Guias de autoria
Equipe
Cal Poly, Team 4-48, Amido Fall 2010 Membro de Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membros
27 Guias de autoria
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
james dee - Responder
make sure you doing it the correct side!
Robert Stokes-Barnett -
muy bueno gracias bro
Tony Fernandez - Responder
Adicione um comentário
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 152
All Time: 33,288
