Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Identify the Hard Drive in the case.
Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
8 outras pessoas executaram este guia.
Um comentário
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
