Ir para o conteúdo principal
Dell OptiPlex FX170 Motherboard Replacement
O que você precisa
  1. Dell OptiPlex FX170 Motherboard Replacement, Case: passo 1, imagem 1 %32
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Motherboard Replacement: passo 2, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 2, imagem 2 %32
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Motherboard Replacement: passo 3, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 3, imagem 2 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 3, imagem 3 %32
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Motherboard Replacement: passo 4, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 4, imagem 2 %32
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Motherboard Replacement, RAM: passo 5, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement, RAM: passo 5, imagem 2 %32
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 Motherboard Replacement: passo 6, imagem 1 %32
    • Lift and pull out the RAM.
  7. Dell OptiPlex FX170 Motherboard Replacement, Memory Board: passo 7, imagem 1 %32
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
  8. Dell OptiPlex FX170 Motherboard Replacement, CMOS Battery: passo 8, imagem 1 %32
    • To remove the battery, pull up on the connector that is plugged into the motherboard.
  9. Dell OptiPlex FX170 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Remove the two 4mm Phillips #00 screws that are along the back of the case.
  10. Dell OptiPlex FX170 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the two foam bumpers that lie on top of the two front USB ports with fingers. Do not throw them away.
  11. Dell OptiPlex FX170 Motherboard Replacement: passo 11, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the speaker cable from the motherboard by gently pulling it straight up to disengage it from the port.
    • Remove the four 4mm Philips #0 screws that secure the motherboard to the case.
    • The screw in the corner where the RAM is located is covered by a small piece of Mylar tape, peel this tape back to reveal the screw. The tweezers can be helpful for this.
  12. Dell OptiPlex FX170 Motherboard Replacement: passo 12, imagem 1 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 12, imagem 2 %32 Dell OptiPlex FX170 Motherboard Replacement: passo 12, imagem 3 %32
    • Gently grasp the motherboard by the heat sink (the black finned piece). Lift the motherboard at an angle such that the ports along the back side come up first.
    • Continue lifting the motherboard, then slowly tilt the piece off to the right to break the Mylar tape over the front USB ports.
    • Be careful when handling the motherboard to prevent electro-static discharge (ESD) damage. If the motherboard is being removed as part of a prerequisite, place the motherboard into a bag designed to prevent a build up of a static charge (usually referred to as a static bag).
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,509
