Ir para o conteúdo principal
Dell Netbook e6400 keyboard Replacement
O que você precisa
  1. Dell Netbook e6400  keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • remove battery
  2. Dell Netbook e6400  keyboard Replacement: passo 2, imagem 1 %32 Dell Netbook e6400  keyboard Replacement: passo 2, imagem 2 %32
    • Remove the card from the slots by pulling the tab
    • Levering on the plastic hooks, the upper line of keys that give access to the keyboard fixing screws is released at the front
  3. Dell Netbook e6400  keyboard Replacement: passo 3, imagem 1 %32
    • Pry underneath to extract the upper line of keys
  4. Dell Netbook e6400  keyboard Replacement: passo 4, imagem 1 %32 Dell Netbook e6400  keyboard Replacement: passo 4, imagem 2 %32 Dell Netbook e6400  keyboard Replacement: passo 4, imagem 3 %32
    • Unscrew the two Phillips screws that hold the keyboard attached to the notebook body
    • New line.itlick the black tab to pull back and to the other to unhook the keyboard
Conclusão
to reassemble your device follow these instructions in reverse order
8 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
it en
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Smilzo
Membro desde: 11/09/13
11.849 Reputação
Autoria de 39 guias
2 comentários
ciao and thanks for this guide @smilzo !
I recently had to re-seat the keyboard, which is a common trick for old Dell laptops when the keyboards starts having issues and types nonsense. However after putting it back together, the keyboard doesn’t light up anymore. what am I doing wrong? did I miss a connector?
alfx - Responder
hi, sorry for what happened, try to disassemble the keyboard again and check that the connectors are inserted well on the correct side and that the cable has not broken.  good luck
Smilzo -
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 28
Ao todo: 1,706
