Ir para o conteúdo principal
Dell Latitude X300 RAM Replacement
O que você precisa
  1. Dell Latitude X300 RAM Replacement, RAM: passo 1, imagem 1 %32 Dell Latitude X300 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Dell Latitude X300 RAM Replacement: passo 2, imagem 1 %32
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Dell Latitude X300 RAM Replacement: passo 3, imagem 1 %32
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Dell Latitude X300 RAM Replacement: passo 4, imagem 1 %32
    • Insert the new memory at 45 degree angle.
  5. Dell Latitude X300 RAM Replacement: passo 5, imagem 1 %32
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Conclusão
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
Membro desde: 01/20/12
23 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-20, Maness Winter 2012 Membro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 2,264
