Ir para o conteúdo principal
Dell Latitude X300 Keyboard Replacement
O que você precisa
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude X300 Keyboard Replacement: passo 2, imagem 2 %32
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: passo 3, imagem 1 %32
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: passo 4, imagem 1 %32
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Conclusão
Jacob Egorov
Membro desde: 01/20/12
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-20, Maness Winter 2012 Membro de Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 21
Ao todo: 1,281
