Ir para o conteúdo principal
Dell Latitude E7470 Speakers Replacement
O que você precisa
  1. Dell Latitude E7470 Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Speakers Replacement, Battery: passo 2, imagem 1 %32
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Speakers Replacement: passo 3, imagem 1 %32 Dell Latitude E7470 Speakers Replacement: passo 3, imagem 2 %32
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Speakers Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Speakers Replacement, Speakers: passo 5, imagem 1 %32 Dell Latitude E7470 Speakers Replacement, Speakers: passo 5, imagem 2 %32
    • Unplug the four pin speaker connector from the motherboard.
  6. Dell Latitude E7470 Speakers Replacement: passo 6, imagem 1 %32 Dell Latitude E7470 Speakers Replacement: passo 6, imagem 2 %32
    • De-route the speaker wire harness from the guide rails.
  7. Dell Latitude E7470 Speakers Replacement: passo 7, imagem 1 %32 Dell Latitude E7470 Speakers Replacement: passo 7, imagem 2 %32 Dell Latitude E7470 Speakers Replacement: passo 7, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the left and right mouse button assembly screws.
    • This allows you to slightly lift the assembly and gain full access to the wire harness that links the left and right speaker units. You do not need to fully remove the button assembly.
  8. Dell Latitude E7470 Speakers Replacement: passo 8, imagem 1 %32 Dell Latitude E7470 Speakers Replacement: passo 8, imagem 2 %32 Dell Latitude E7470 Speakers Replacement: passo 8, imagem 3 %32
    • Starting with the left speaker (your right), carefully lift the units away and de-route the wire harness linking them.
    • Take note of the soft boots that hold each speaker in place. They should lift freely away, but if needed you may wedge them loose by hand or with your spudger.
Conclusão
DCurrent
Membro desde: 02/06/22
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 817
