Introdução
This guide introduces how to remove the battery from Dell Latitude E7470. The laptop comes with different battery configurations. While this guide shows how to replace a standard capacity battery, the procedure is similar when replacing the extended capacity battery.
Ferramentas
Peças
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
4 outras pessoas concluíram este guia.
