Ir para o conteúdo principal
Dell Latitude E7470 Display Replacement
O que você precisa
  1. Dell Latitude E7470  Display Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
    After unscrewing the 8 screws, they stay on the back cover.
    Victor Ashiedu - Responder
  2. Dell Latitude E7470  Display Replacement, Battery: passo 2, imagem 1 %32
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
    Personally, I would remove the battery as the first stage battery should be disconnected before any work is completed.
    Richard Holmes - Responder
  3. Dell Latitude E7470  Display Replacement: passo 3, imagem 1 %32 Dell Latitude E7470  Display Replacement: passo 3, imagem 2 %32
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
    My laptop had 2 screws holding the battery. I am not sure why. It may be useful to check whether yours has 2 as well. Unlike the laptop’s back cover, after unscrewing the screws on the battery, you have to remove the screws.
    I too have 2 battery screws. My battery is longer than the one pictured. I think my battery must be an extended capacity battery.
    What I do not understand is that in the picture, on the extreme right - next to the computer's outside edge, there is a round CMOS battery pictured with a red/black twisted pair of wires plugging into the motherboard. My machine has an empty space with no battery. What about the machines of others? Was there one that has been removed? My machine seems to work ok without it. Should I install one?
    wilie - Responder
  4. Dell Latitude E7470  Display Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Dell Latitude E7470  Display Replacement, Display: passo 5, imagem 1 %32
    • Remove screws which are indicated by red circles . Gently unplug the write connector, marked by the red square, out of the grey socket.
  6. Dell Latitude E7470  Display Replacement: passo 6, imagem 1 %32
    • Remove wires in protectors (red circles) and remove the screw in red square. Pick the wires out of the motherboard.
  7. Dell Latitude E7470  Display Replacement: passo 7, imagem 1 %32 Dell Latitude E7470  Display Replacement: passo 7, imagem 2 %32 Dell Latitude E7470  Display Replacement: passo 7, imagem 3 %32
    • Remove two side screws on the surface of computer's connector parts.
    • Remove the five 0.4 cm screws in the red circle
  8. Dell Latitude E7470  Display Replacement: passo 8, imagem 1 %32 Dell Latitude E7470  Display Replacement: passo 8, imagem 2 %32
    • Use spudger to pry the display bezel.
  9. Dell Latitude E7470  Display Replacement: passo 9, imagem 1 %32
    • This the screen part can be replaced. Make sure you buy the correct size!
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
You do not need to take the entire computer apart. The bezel can come off while still hinged to the main body giving you access to the four screws holding on the display. Unless you need to replace the main display ribbon cable, the screen itself is straightforward to replace.
Shane Pritchard - Responder
If you are replacing the bezel at the same time - don't forget to check that the clear film has been removed from the webcam lens. A foggy image is not reassuring when testing the reassembled computer.
Hi. Where is the inverter located in an e7470?
Is it integrated along the bottom of the lcd unit? Can it be bought separately and replaced? Thx if you can help.
Howard - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 2,962
