Ir para o conteúdo principal
Dell Latitude E7450 Memory (RAM) Replacement
O que você precisa
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Remove battery and base cover from the computer.
  1. Dell Latitude E7450 Memory (RAM) Replacement, Open retention clips: passo 2, imagem 1 %32
    • Open the retention clips away from the memory chip.
  2. Dell Latitude E7450 Memory (RAM) Replacement, Remove memory chip: passo 3, imagem 1 %32
    • Remove the memory chip from the computer.
    • Put a new memory chip in the memory socket.
    • Push the memory chip until the clips lock it. If a second memory chip needs to be installed, repeat steps 1 through 6.
    • Replace the pre-removal parts in descending order.
    • Install the battery and base cover back on the computer.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,287
