Ir para o conteúdo principal
Dell Latitude E7450 Hard Drive Replacement
O que você precisa
    • Before performing this task, make sure you turn off the computer and disconnect every external device from the machine, be it USB devices, Displays, Power, or anything else.
    • Slide the release latch to unlock the battery before removing it. To remove the base cover, you should remove the Philips head screw on either end of the laptop in the battery compartment, before lifting it up from the screw hole side.
  1. Dell Latitude E7450 Hard Drive Replacement, Disconnect hard drive cable: passo 2, imagem 1 %32
    • Carefully disconnect the Hard Drive from the cable, "walking out" one side at a time with a spudger to ensure you don't damage the connector.
    • Unscrew the retaining screws for the Hard Drive bracket.
    • You will now be able to remove the bracket, taking the drive with it.
  2. Dell Latitude E7450 Hard Drive Replacement, Remove hard drive: passo 3, imagem 1 %32
    • Remove the computer’s hard drive.
    • Install the new drive into the drive bracket, before carefully reconnecting the drive to the cable, and seating it in place.
    • Put the hard-drive bracket on top of the hard drive.
    • Tighten the screws so that they can lock the computer’s hard drive.
    • Connect the hard-drive cable to the system board connector.
    • Install the battery and base cover.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 47
Ao todo: 2,919
