Introdução
Before following this guide, make sure that the device is powered off and that it is unplugged. It is also recommended that you follow the Safety Precautions When Working with Electronic and Electrical Equipment.
O que você precisa
Remove the battery from the computer by sliding the release latch.
Remove the computer cover by unscrewing the two screws highlighted in the picture.
Disconnect the CMOS battery from its connector and remove from the system board.
Replace the battery by plugging the connector to the board and placing the battery in the correct position.
If you are trying to reset the BIOS Admin Password, I would recommend this tutorial :)
