Ir para o conteúdo principal
Dell Latitude E7450 Base Cover Replacement
O que você precisa
  1. Dell Latitude E7450 Base Cover Replacement, Remove battery from computer: passo 1, imagem 1 %32 Dell Latitude E7450 Base Cover Replacement, Remove battery from computer: passo 1, imagem 2 %32
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Slide the release latch to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Latitude E7450 Base Cover Replacement, Removing the Base Cover: passo 2, imagem 1 %32
    • Remove the screws that secure the base cover to the computer [1].
    • Slide the base cover to release it from the computer [2].
  3. Dell Latitude E7450 Base Cover Replacement, Remove the base cover from the computer.: passo 3, imagem 1 %32
    • Remove the base cover from the computer.
    • Place the base cover to align with the screw holes correctly on the computer.
    • Tighten the screws to secure the base cover to the computer.
    • Install the battery back on the computer.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 405
