Ir para o conteúdo principal
Dell Latitude E7440 Keyboard Replacement
O que você precisa
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 3 %32
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 3 %32
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Dell Latitude E7440 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 3 %32
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
Conclusão
6 outras pessoas executaram este guia.
Sheetal Prasanna
Membro desde: 11/06/19
649 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G1, Stella Fall 2019 Membro de IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Membros
Autoria de 3 guias
2 comentários
for step three i would add “ the cables to be removed are under a type of flap/cover”. I don’t know if we have to be specific on what tools we used. If we do have to be specific than we will just add them. Other than that great work!
Oscar Aca - Responder
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
Jamie O'Hare - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 5,439
