Ir para o conteúdo principal
Dell Latitude E7440 Battery Replacement
O que você precisa
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: passo 1, imagem 1 %32
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, imagem 1 %32 Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, imagem 2 %32 Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, imagem 3 %32
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: passo 3, imagem 1 %32
    • Lift the battery by the top, away from the laptop body.
Conclusão
9 outras pessoas executaram este guia.
Akash Kedia
Membro desde: 01/24/19
1.445 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, White Winter 2019 Membro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Membros
Autoria de 5 guias
2Comentários do guia
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - Responder
Any recommended site to buy original battery?
Razin Ahmed - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 85
Ao todo: 5,850
