Ir para o conteúdo principal
Dell Latitude E7250 SSD Replacement
O que você precisa
  1. Dell Latitude E7250 SSD Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude E7250 SSD Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: passo 2, imagem 1 %32 Dell Latitude E7250 SSD Replacement, SSD: passo 2, imagem 2 %32 Dell Latitude E7250 SSD Replacement, SSD: passo 2, imagem 3 %32
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: passo 3, imagem 1 %32 Dell Latitude E7250 SSD Replacement: passo 3, imagem 2 %32 Dell Latitude E7250 SSD Replacement: passo 3, imagem 3 %32
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
Conclusão
7 outras pessoas executaram este guia.
Um comentário
Thanks a lot for this !
viperx007 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 32
Últimos 30 dias: 131
Duração total: 10,601
