Ir para o conteúdo principal
Dell Latitude E7250 RAM Replacement
O que você precisa
  1. Dell Latitude E7250 RAM Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude E7250 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: passo 2, imagem 1 %32 Dell Latitude E7250 RAM Replacement, RAM: passo 2, imagem 2 %32 Dell Latitude E7250 RAM Replacement, RAM: passo 2, imagem 3 %32
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: passo 3, imagem 1 %32 Dell Latitude E7250 RAM Replacement: passo 3, imagem 2 %32 Dell Latitude E7250 RAM Replacement: passo 3, imagem 3 %32
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 58
Duração total: 4,782
