Introdução
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
O que você precisa
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
Uma outra pessoa concluiu este guia.
