Ir para o conteúdo principal
Dell Latitude E6510 Heat Sink Replacement
O que você precisa
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: passo 1, imagem 1 %32 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: passo 1, imagem 2 %32 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: passo 1, imagem 3 %32
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: passo 2, imagem 1 %32 Dell Latitude E6510  Heat Sink Replacement: passo 2, imagem 2 %32 Dell Latitude E6510  Heat Sink Replacement: passo 2, imagem 3 %32
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: passo 3, imagem 1 %32 Dell Latitude E6510  Heat Sink Replacement: passo 3, imagem 2 %32 Dell Latitude E6510  Heat Sink Replacement: passo 3, imagem 3 %32
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: passo 4, imagem 1 %32 Dell Latitude E6510  Heat Sink Replacement: passo 4, imagem 2 %32 Dell Latitude E6510  Heat Sink Replacement: passo 4, imagem 3 %32
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: passo 5, imagem 1 %32
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: passo 6, imagem 1 %32 Dell Latitude E6510  Heat Sink Replacement: passo 6, imagem 2 %32 Dell Latitude E6510  Heat Sink Replacement: passo 6, imagem 3 %32
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Duração total: 1,038
