Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Push the tabs on the left and right of the battery out towards the edge of the case.
While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
Push the button in on the CD/DVD drive to eject the drive.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
Use the plastic opening tool to unclip the connector.
4 outras pessoas executaram este guia.
Um comentário
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
