Ir para o conteúdo principal
Dell Latitude E6420 Fan Replacement
O que você precisa
  1. Dell Latitude E6420 Fan Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude E6420 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Fan Replacement: passo 2, imagem 1 %32
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Fan Replacement, CD/DVD Drive: passo 3, imagem 1 %32 Dell Latitude E6420 Fan Replacement, CD/DVD Drive: passo 3, imagem 2 %32
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Fan Replacement: passo 4, imagem 1 %32 Dell Latitude E6420 Fan Replacement: passo 4, imagem 2 %32
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Fan Replacement, Backplate: passo 5, imagem 1 %32 Dell Latitude E6420 Fan Replacement, Backplate: passo 5, imagem 2 %32
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Fan Replacement: passo 6, imagem 1 %32 Dell Latitude E6420 Fan Replacement: passo 6, imagem 2 %32
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Fan Replacement, Fan: passo 7, imagem 1 %32 Dell Latitude E6420 Fan Replacement, Fan: passo 7, imagem 2 %32
    • Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
  8. Dell Latitude E6420 Fan Replacement: passo 8, imagem 1 %32 Dell Latitude E6420 Fan Replacement: passo 8, imagem 2 %32
    • Use the plastic opening tool to unclip the connector.
  9. Dell Latitude E6420 Fan Replacement: passo 9, imagem 1 %32
    • Lift the fan out of the laptop.
Conclusão
4 outras pessoas executaram este guia.
Madysen Eames
Membro desde: 02/27/18
1.528 Reputação
Autoria de 7 guias
Equipe
Um comentário
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
Godwin Nwachukwu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 2,162
