Introdução
If the fan isn't working properly, the laptop can overheat. This guide will show users how to replace the fan.
O que você precisa
Push the tabs on the left and right of the battery out towards the edge of the case.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
4 outras pessoas executaram este guia.
Um comentário
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
