Introdução
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
O que você precisa
Push the tabs on the left and right of the battery out towards the edge of the case.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
4 outras pessoas executaram este guia.
