Ir para o conteúdo principal
Dell Latitude E6400 CPU Replacement
O que você precisa
  1. Dell Latitude E6400 CPU Replacement, Battery Removal: passo 1, imagem 1 %32 Dell Latitude E6400 CPU Replacement, Battery Removal: passo 1, imagem 2 %32 Dell Latitude E6400 CPU Replacement, Battery Removal: passo 1, imagem 3 %32
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 CPU Replacement, Bottom Lid: passo 2, imagem 1 %32 Dell Latitude E6400 CPU Replacement, Bottom Lid: passo 2, imagem 2 %32
    • Remove the one 7.5 mm Phillips screw securing the bottom case.
    • Pull the bottom lid towards yourself to remove it.
  3. Dell Latitude E6400 CPU Replacement, Fan: passo 3, imagem 1 %32 Dell Latitude E6400 CPU Replacement, Fan: passo 3, imagem 2 %32 Dell Latitude E6400 CPU Replacement, Fan: passo 3, imagem 3 %32
    • Remove the two 4.8mm Phillips screws securing the fan.
    • Disconnect the fan by pulling power cable straight up.
    • Lift the fan with your finger and slide it out towards the inside of the laptop.
  4. Dell Latitude E6400 CPU Replacement, Heat Sink: passo 4, imagem 1 %32 Dell Latitude E6400 CPU Replacement, Heat Sink: passo 4, imagem 2 %32
    • Remove the four Phillips screws securing the heat sink.
    • Using your finger gently lift and remove heat sink .
  5. Dell Latitude E6400 CPU Replacement: passo 5, imagem 1 %32
    • Gently rotate left the locking screw to release CPU from its socket.
    • Lift the CPU straight up of it's socket.
Conclusão
D. K. Labudek
Membro desde: 03/09/18
685 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 445
