O que você precisa
Slide the release latches to unlock the battery.
Remove the battery from the computer.
Pry the top edge of the display bezel.
Work your way along to the sides and bottom edge of the display bezel
Remove the display bezel from the display assembly
Remove the 6 (M2 x 3mm) screws that secure the display panel to the display assembly
Flip the display panel over
Peel off the LVDS cable connector tape and disconnect the LVDS cable from the display panel
Remove the display panel from the display assembly
