Ir para o conteúdo principal
Dell Latitude E5550-5550 Coin Cell Battery Replacement
O que você precisa
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, base cover, memory module, and hard-drive assembly, keyboard trim, keyboard [itself], palmrest, display hinge-brackets, display assembly, system fan, and system board from the computer.
  1. Dell Latitude E5550-5550 Coin Cell Battery Replacement, Disconnect & remove coin-cell battery.: passo 2, imagem 1 %32
    • Disconnect the coin-cell battery cable from its connector on the system board [1].
    • Pry the coin-cell battery to release from the adhesive and remove from the system board [2].
    • Place the coin-cell battery into its slot on the system board.
    • Connect the coin-cell battery cable to its connector on the system board.
    • Install the system board, system fan, display assembly, display-hinge brackets, palmrest, keyboard [itself], keyboard trim, hard-drive assembly, memory, battery, and base cover for the computer.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
2Comentários do guia
Do you know if it is possible to upgrade the motherboard during this processor
Chico Lopez - Responder
Sorry for the late response. Yes; it's possible to upgrade the motherboard/system board during this process. You'll just have to check if the motherboard fits your Latitude E5550 as per the sources below.
(Main source: https://www.parts-people.com/index.php?a...
DELL Community source: https://www.dell.com/community/en/conver...).
Hezekiah Brown -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 478
