Introdução
If the user would like to reapply faulty or low quality thermal compound, this guide will give step by step information on how to achieve this.
O que você precisa
Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
The system's heatsink is the copper pipe and large metal assembly held down by five screws.
Remove the five Phillips #1 screws in the order numbered on the metal assembly.
To reassemble your device, follow steps 1-7 in reverse order.
4 outras pessoas executaram este guia.
Um comentário
Great post and i followed the mentioned steps. Now, my cpu heat rate low down to 20%. thanks for such a wonderful article. Happy Fathers Day to all of you.
