Ir para o conteúdo principal
Dell Latitude E5500 CD ROM Drive Replacement
O que você precisa
  1. Dell Latitude E5500 CD ROM Drive Replacement, CD ROM Drive: passo 1, imagem 1 %32
    • Place the front of the laptop on the table so that the hinges are facing away from yourself.
  2. Dell Latitude E5500 CD ROM Drive Replacement: passo 2, imagem 1 %32
    • Remove the screw located in the red circle shown.
  3. Dell Latitude E5500 CD ROM Drive Replacement: passo 3, imagem 1 %32
    • Apply a small amount of pressure and slide the cover towards yourself in the direction indicated.
  4. Dell Latitude E5500 CD ROM Drive Replacement: passo 4, imagem 1 %32 Dell Latitude E5500 CD ROM Drive Replacement: passo 4, imagem 2 %32
    • Locate the slot for the CD ROM ejector found inside the red box shown.
  5. Dell Latitude E5500 CD ROM Drive Replacement: passo 5, imagem 1 %32 Dell Latitude E5500 CD ROM Drive Replacement: passo 5, imagem 2 %32
    • Using a #2 Phillip's head screwdriver, push the CD ROM ejector to the left.
    • Once the CD ROM clicks out, carefully slide it out of the laptop.
Conclusão
To reassemble your device, follow these instructions in reverse order using your new CD Rom.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 616
