Ir para o conteúdo principal
Dell Latitude E5500 CD ROM Drive Replacement
O que você precisa
  1. Dell Latitude E5500 CD ROM Drive Replacement, CD ROM Drive: passo 1, imagem 1 %32
    • Place the front of the laptop on the table so that the hinges are facing away from yourself.
  2. Dell Latitude E5500 CD ROM Drive Replacement: passo 2, imagem 1 %32
    • Remove the screw located in the red circle shown.
  3. Dell Latitude E5500 CD ROM Drive Replacement: passo 3, imagem 1 %32
    • Apply a small amount of pressure and slide the cover towards yourself in the direction indicated.
  4. Dell Latitude E5500 CD ROM Drive Replacement: passo 4, imagem 1 %32 Dell Latitude E5500 CD ROM Drive Replacement: passo 4, imagem 2 %32
    • Locate the slot for the CD ROM ejector found inside the red box shown.
  5. Dell Latitude E5500 CD ROM Drive Replacement: passo 5, imagem 1 %32 Dell Latitude E5500 CD ROM Drive Replacement: passo 5, imagem 2 %32
    • Using a #2 Phillip's head screwdriver, push the CD ROM ejector to the left.
    • Once the CD ROM clicks out, carefully slide it out of the laptop.
Conclusão
To reassemble your device, follow these instructions in reverse order using your new CD Rom.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 34
Ao todo: 688
