Ir para o conteúdo principal
Dell Latitude E5430 Hard Drive Replacement
O que você precisa
  1. Dell Latitude E5430 Hard Drive Replacement, Remove the Battery: passo 1, imagem 1 %32
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Dell Latitude E5430 Hard Drive Replacement, Remove the Bottom Cover: passo 2, imagem 1 %32
    • Remove two Phillips head screws from the bottom cover.
  3. Dell Latitude E5430 Hard Drive Replacement, Remove the Hard Drive Caddy: passo 3, imagem 1 %32
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  4. Dell Latitude E5430 Hard Drive Replacement, Unscrew the Hard Drive from the Caddy: passo 4, imagem 1 %32
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  5. Dell Latitude E5430 Hard Drive Replacement, Done!: passo 5, imagem 1 %32
    • Congratulations, you've done it!
Conclusão
After you have installed your new hard drive or SSD, repeat the process in reverse.
5 outras pessoas executaram este guia.
Sam
Membro desde: 02/24/17
666 Reputação
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 3,992
