Ir para o conteúdo principal
Dell Latitude E5400 Memory Upgrade / Replacement
O que você precisa
  1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove battery: passo 1, imagem 1 %32
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: passo 2, imagem 1 %32 Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: passo 2, imagem 2 %32
    • Losen all four screws and remove the backpanel.
    • Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Dell Latitude E5400 Memory Upgrade / Replacement, change/upgrade the memory: passo 3, imagem 1 %32
    • Now you can upgrade or change the memory.
    • NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
Conclusão
Uma outra pessoa concluiu este guia.
Robin Koch
Membro desde: 03/25/17
289 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 2,179
