Introdução
If your laptop is experiencing slow boot times, errors on start-up, or failure to boot up, it may be time to replace the hard drive. Replacing the hard drive is also a good option if you need to increase storage space or loading speeds in your laptop.
Be sure that all of your data is backed up properly before proceeding with the hard drive replacement.
O que você precisa
Remove the two 3mm Phillips #1 screws that secure the hard drive in place.
7 outras pessoas executaram este guia.
