Ir para o conteúdo principal
Dell Latitude E4310 Display Replacement
O que você precisa
  1. Dell Latitude E4310 Display Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: passo 2, imagem 1 %32 Dell Latitude E4310 Display Replacement: passo 2, imagem 2 %32
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: passo 3, imagem 1 %32 Dell Latitude E4310 Display Replacement, Display: passo 3, imagem 2 %32 Dell Latitude E4310 Display Replacement, Display: passo 3, imagem 3 %32
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: passo 4, imagem 1 %32 Dell Latitude E4310 Display Replacement: passo 4, imagem 2 %32
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: passo 5, imagem 1 %32 Dell Latitude E4310 Display Replacement: passo 5, imagem 2 %32
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: passo 6, imagem 1 %32 Dell Latitude E4310 Display Replacement: passo 6, imagem 2 %32
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: passo 7, imagem 1 %32 Dell Latitude E4310 Display Replacement: passo 7, imagem 2 %32 Dell Latitude E4310 Display Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: passo 8, imagem 1 %32
    • Remove the screen from the laptop.
Conclusão
6 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 37
Ao todo: 1,637
