O que você precisa
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
Once you removed the back panel, the RAM will easily be located.
Place your thumbs on each side of the RAM tabs.
Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
