Ir para o conteúdo principal
Dell Latitude E4200 RAM Replacement
O que você precisa
  1. Dell Latitude E4200 RAM Replacement, Back Panel: passo 1, imagem 1 %32
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 RAM Replacement: passo 2, imagem 1 %32 Dell Latitude E4200 RAM Replacement: passo 2, imagem 2 %32 Dell Latitude E4200 RAM Replacement: passo 2, imagem 3 %32
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 RAM Replacement: passo 3, imagem 1 %32
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 RAM Replacement, Remove the back panel: passo 4, imagem 1 %32
    • Once you removed the back panel, the RAM will easily be located.
    • Be sure to remove the battery first
  5. Dell Latitude E4200 RAM Replacement, Take out the RAM: passo 5, imagem 1 %32 Dell Latitude E4200 RAM Replacement, Take out the RAM: passo 5, imagem 2 %32
    • Place your thumbs on each side of the RAM tabs.
    • Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
    • The RAM should "bump up" after you push away the tabs.
  6. Dell Latitude E4200 RAM Replacement: passo 6, imagem 1 %32 Dell Latitude E4200 RAM Replacement: passo 6, imagem 2 %32 Dell Latitude E4200 RAM Replacement: passo 6, imagem 3 %32
    • Gently grab each side of the RAM and remove it from the device.
    • Please do not touch connection side of the RAM (shown in orange) with fingers. It might causes possible corrosion to the connection.
Conclusão
Chao Wei
Membro desde: 03/22/15
146 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 5-6, Williams Spring 2015 Membro de Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 2,775
