Ir para o conteúdo principal
Dell Latitude E4200 Keyboard Replacement
O que você precisa
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: passo 1, imagem 1 %32
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: passo 3, imagem 1 %32
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude E4200 Keyboard Replacement: passo 5, imagem 2 %32
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: passo 6, imagem 1 %32
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: passo 7, imagem 1 %32
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: passo 8, imagem 1 %32
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: passo 9, imagem 1 %32
    • Completely lift the keyboard from the device, as they are now disassembled.
Conclusão
3 outras pessoas executaram este guia.
Equipe
Baylor, Team 5-6, Williams Spring 2015 Membro de Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 27
Duração total: 4,398
