Introdução
Introduction
The touch pad is critical to addressing almost all elements of the laptop. If damaged and needs to be replaced following this guide will help. In the meantime you may plug in an external mouse until you are able to fix the touch pad.
This Guide Will Teach You
- The basic safety steps to follow when fixing the laptop
- To disassemble of the laptops internals and reach the Touch Pad
- Precautions to prevent further damage to the laptop
- Tools needed for the repair
Ferramentas
Peças
Nenhum componente especificado.
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
Find and remove the display's ribbon cable by gently pulling on the blue tab indicated in the picture.
While tracing the path of the cable back to the display, unhook the cable from the tabs of the body using the spudger.
Remove the connector to the coin using the spudger.
Slide the coin battery out of its slot by wiggling its connector with a gentle tug.
You may also need to use the spudger to carefully push out the battery from the top of the slot where the yellow square is.
Carefully, close the laptop and turn it over.
Remove the seven screws (M2.5-8mm) indicated to the left and place them in a labeled container.
Remove the black and white cables on the wireless card using the tweezers by pulling upward.
While tracing the path of the black and white cables back to the display, unhook the cablse from the tabs of the body using the spudger. Both wires need to be completely out of all the tabs, loose and unattached.
Using the spudger, go around the perimeter of the laptop and separate the black-grey palm rest layer from the lighter-grey base layer.
It's easiest to start in an opening near the display input ports on the back of the laptop and make your way around.
Once all of the tabs have been unlatched, remove the palm rest layer.
To reassemble your device, follow these instructions in reverse order with your new touchpad.
4 outras pessoas concluíram este guia.
