Ir para o conteúdo principal
Dell Latitude D630 Keyboard Replacement
O que você precisa
  1. Dell Latitude D630 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Keyboard Replacement: passo 2, imagem 1 %32
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Dell Latitude D630 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Dell Latitude D630 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude D630 Keyboard Replacement: passo 5, imagem 2 %32
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude D630 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
Conclusão
15 outras pessoas executaram este guia.
Jon Amireh
Membro desde: 01/17/13
1.696 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-1, Johann Winter 2013 Membro de Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
Membros da 4
Autoria de 10 guias
3 comentários
These instructions were A+ fantastic! I have NEVER done any kind of computer dis-assembly OR re-assembly before. Your directions and pictures helped me feel confident from start to finish with a 100% success on the first try. I bought my son a Dell 630 to play Minecraft on and it needed a new keyboard, so THANK YOU, THANK YOU for making it possible for me do this so flawlessly. :-)
Tamara
Tamara - Responder
Good job, easy to follow instructions without being over the top, good quality photos
Gordon McIntosh - Responder
THIS I like !!! Finally, a series of shown steps that most anyone with brain can understand and do. My keyboard is worn out, there are wear holes in several keys.... yea, it is time to replace it and .... NOW WE CAN !
Warren
Warren Sjoberg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 7,739
