Ir para o conteúdo principal
Dell Latitude D630 Hard Drive Replacement
O que você precisa
  1. Dell Latitude D630 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: passo 2, imagem 1 %32
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Dell Latitude D630 Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: passo 4, imagem 1 %32
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Latitude D630 Hard Drive Replacement: passo 5, imagem 2 %32
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusão
17 outras pessoas executaram este guia.
Savi Chavan
Membro desde: 03/12/14
979 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-4, Cichon Spring 2014 Membro de UMass Dartmouth, Team 1-4, Cichon Spring 2014
UMASSD-CICHON-S14S1G4
Membros da 3
1 Guia de autoria
4 comentários
Dell latitude 2RHczd1
C Chandler - Responder
I appreciate the guide my good sir. Very helpful.
Matt Erti - Responder
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 37
Duração total: 15,425
