Ir para o conteúdo principal
Dell Latitude D620 Keyboard Replacement
O que você precisa
  1. Dell Latitude D620 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Mera display ka masla hai
    manaqib arif - Responder
  2. Dell Latitude D620 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude D620 Keyboard Replacement: passo 2, imagem 2 %32 Dell Latitude D620 Keyboard Replacement: passo 2, imagem 3 %32
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Keyboard Replacement: passo 3, imagem 1 %32
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Keyboard Replacement: passo 4, imagem 1 %32
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude D620 Keyboard Replacement: passo 5, imagem 2 %32
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude D620 Keyboard Replacement: passo 6, imagem 2 %32
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Keyboard Replacement: passo 7, imagem 1 %32
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
Conclusão
10 outras pessoas executaram este guia.
Miguel Wong
Membro desde: 04/15/10
562 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-35, Regan Spring 2010 Membro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
Membros da 4
Autoria de 4 guias
Um comentário
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 16,773
