Ir para o conteúdo principal
Dell Latitude D620 Display Replacement
O que você precisa
  1. Dell Latitude D620 Display Replacement, Keyboard: passo 1, imagem 1 %32
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Mera display ka masla hai
    manaqib arif - Responder
  2. Dell Latitude D620 Display Replacement: passo 2, imagem 1 %32 Dell Latitude D620 Display Replacement: passo 2, imagem 2 %32 Dell Latitude D620 Display Replacement: passo 2, imagem 3 %32
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: passo 3, imagem 1 %32
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: passo 4, imagem 1 %32
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: passo 5, imagem 1 %32 Dell Latitude D620 Display Replacement: passo 5, imagem 2 %32
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: passo 6, imagem 1 %32 Dell Latitude D620 Display Replacement: passo 6, imagem 2 %32
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: passo 7, imagem 1 %32
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: passo 8, imagem 1 %32
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: passo 9, imagem 1 %32
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: passo 10, imagem 1 %32 Dell Latitude D620 Display Replacement: passo 10, imagem 2 %32
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: passo 11, imagem 1 %32 Dell Latitude D620 Display Replacement: passo 11, imagem 2 %32
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: passo 12, imagem 1 %32
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: passo 13, imagem 1 %32
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: passo 14, imagem 1 %32
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: passo 15, imagem 1 %32
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: passo 16, imagem 1 %32
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: passo 17, imagem 1 %32
    • Carefully lift the LCD screen out of its casing
Conclusão
19 outras pessoas executaram este guia.
Miguel Wong
Membro desde: 04/15/10
556 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-35, Regan Spring 2010 Membro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
Membros da 4
Autoria de 4 guias
Um comentário
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 32,984
