Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Replacing a defective modem is fairly simple and will help your computer in connecting to networks requiring a modem.
Peças
Nenhum componente especificado.
  1. Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Remove the battery from its compartment.
    • Remove the battery from its compartment.
  4. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  5. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
    • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  6. Lift and remove the lid. Lift and remove the lid.
    • Lift and remove the lid.
  7. Remove the 3.9mm Philips #1 screw on top of the modem. Remove the 3.9mm Philips #1 screw on top of the modem.
    • Remove the 3.9mm Philips #1 screw on top of the modem.
  8. Pull on the white tab to remove the modem Remove the cable going to the modem. Remove the cable going to the modem.
    • Pull on the white tab to remove the modem
    • Remove the cable going to the modem.
Conclusão
Uma outra pessoa concluiu este guia.
Jose Chavez
Membro desde: 26-01-2014
113 Reputação
Autoria de 1 guia
equipe
Cal Poly, Team 6-24, Maness Winter 2014 Membro de Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Membros
5 Guias de autoria
I have manufacturing mode problem can you help me??
Mod - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,343
