Ir para o conteúdo principal
Dell Latitude D610 Keyboard Replacement
O que você precisa
  1. Dell Latitude D610 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude D610 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude D610 Keyboard Replacement: passo 2, imagem 2 %32 Dell Latitude D610 Keyboard Replacement: passo 2, imagem 3 %32
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Latitude D610 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Latitude D610 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude D610 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude D610 Keyboard Replacement: passo 6, imagem 2 %32
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: passo 7, imagem 1 %32 Dell Latitude D610 Keyboard Replacement: passo 7, imagem 2 %32 Dell Latitude D610 Keyboard Replacement: passo 7, imagem 3 %32
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
Conclusão
4 outras pessoas executaram este guia.
Jordan Barham
Membro desde: 01/26/14
459 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-24, Maness Winter 2014 Membro de Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 2,059
