Ir para o conteúdo principal
Dell Latitude D610 Fan Replacement
O que você precisa
  1. Dell Latitude D610 Fan Replacement, Battery: passo 1, imagem 1 %32 Dell Latitude D610 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Fan Replacement: passo 2, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 2, imagem 2 %32 Dell Latitude D610 Fan Replacement: passo 2, imagem 3 %32
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Fan Replacement: passo 3, imagem 1 %32
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Fan Replacement, Keyboard: passo 4, imagem 1 %32 Dell Latitude D610 Fan Replacement, Keyboard: passo 4, imagem 2 %32 Dell Latitude D610 Fan Replacement, Keyboard: passo 4, imagem 3 %32
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Fan Replacement: passo 5, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 5, imagem 2 %32
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Fan Replacement: passo 6, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 6, imagem 2 %32
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Fan Replacement: passo 7, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 7, imagem 2 %32 Dell Latitude D610 Fan Replacement: passo 7, imagem 3 %32
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
  8. Dell Latitude D610 Fan Replacement, Fan: passo 8, imagem 1 %32 Dell Latitude D610 Fan Replacement, Fan: passo 8, imagem 2 %32
    • Remove the two 3.9mm Philips #1 screws from the case.
  9. Dell Latitude D610 Fan Replacement: passo 9, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 9, imagem 2 %32
    • Remove the sixteen 3.9mm Philips #1 screws from the back.
  10. Dell Latitude D610 Fan Replacement: passo 10, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 10, imagem 2 %32 Dell Latitude D610 Fan Replacement: passo 10, imagem 3 %32
    • Turn the computer over. Using an opening tool seperate the top cover from the rest of the frame.
    • Do not open the computer too widely or quickly. Doing so will result in damage to the computer.
  11. Dell Latitude D610 Fan Replacement: passo 11, imagem 1 %32 Dell Latitude D610 Fan Replacement: passo 11, imagem 2 %32 Dell Latitude D610 Fan Replacement: passo 11, imagem 3 %32
    • Remove the 3.9 mm Philips #1 screw.
    • Unplug the fan cable.
    • Lift fan out of compartment to remove the fan.
Conclusão
Jordan Barham
Membro desde: 01/26/14
459 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-24, Maness Winter 2014 Membro de Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 3,277
