Introdução
Replacing a defective battery is pretty easy and will increase the time your computer will last after charging.
Peças
Não são necessárias peças.
  1. Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  4. Remove the battery from its compartment.
    • Remove the battery from its compartment.
Conclusão
4 outras pessoas concluíram este guia.
Cinthya
446 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-24, Maness Winter 2014 Membro de Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 21
Todo: 1,543
