Ir para o conteúdo principal
Dell Latitude D600 Thermal Paste Replacement
O que você precisa
  1. Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 1 %32 Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 2 %32 Dell Latitude D600 Thermal Paste Replacement, Opening the laptop.: passo 1, imagem 3 %32
    • Use a prying tool to remove the top panel.
    • This will reveal 2 screws that hold the keyboard in place, remove them.
    • After that - carefully unplug the keyboard and set it aside.
  2. Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: passo 2, imagem 1 %32 Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: passo 2, imagem 2 %32 Dell Latitude D600 Thermal Paste Replacement, Cleaning the old thermal paste.: passo 2, imagem 3 %32
    • Unscrew the 4 screws that hold the CPU heatsink in place.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  3. Dell Latitude D600 Thermal Paste Replacement, Applying new thermal paste.: passo 3, imagem 1 %32
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
Conclusão
Simeon Brankov
Membro desde: 11/08/20
7.153 Reputação
Autoria de 54 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 26
