Ir para o conteúdo principal
Dell Latitude D600 RAM (Main Memory) Replacement
O que você precisa
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: passo 1, imagem 1 %32
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: passo 2, imagem 1 %32 Dell Latitude D600 RAM (Main Memory) Replacement: passo 2, imagem 2 %32
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: passo 3, imagem 1 %32
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): passo 4, imagem 1 %32 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): passo 4, imagem 2 %32
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, imagem 1 %32 Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, imagem 2 %32 Dell Latitude D600 RAM (Main Memory) Replacement: passo 5, imagem 3 %32
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: passo 6, imagem 1 %32
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, imagem 1 %32 Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, imagem 2 %32 Dell Latitude D600 RAM (Main Memory) Replacement: passo 7, imagem 3 %32
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: passo 8, imagem 1 %32
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Conclusão
6 outras pessoas executaram este guia.
Joseph
Membro desde: 07/16/14
1.497 Reputação
Autoria de 5 guias
Um comentário
Almost perfect: easy; clear;
Herman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 2,913
