Ir para o conteúdo principal
Dell Latitude D531 Keyboard Replacement
O que você precisa
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery and hinge cover.
  1. Dell Latitude D531 Keyboard Replacement, Remove screw at the top of the keyboard; lift keyboard.: passo 2, imagem 1 %32
    • Remove the three screws at the top of the keyboard.
    • The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Lift the keyboard only enough to hold it up and slightly forward to allow access to the keyboard connector on the system board.
    • To release the keyboard cable from the connector on the system board, rotate the plastic bar on the keyboard connector.
    • To avoid scratching the palm rest when replacing the keyboard, hook the tabs along the front edge of the keyboard into the palm rest, and then secure the keyboard in place.
    • To replace the keyboard, connect the keyboard cable to the connector on the system board.
    • Place the tabs along the front edge of the keyboard into the palm rest, and lay the keyboard down on the palm rest.
    • Replace the three screws at the top of the keyboard.
    • Replace the hinge cover.
    • Install the battery.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 158
