Ir para o conteúdo principal
Dell Latitude D531 Coin Cell Battery Replacement
O que você precisa
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching a connector on the back panel of the computer.
    • Remove the battery.
  1. Dell Latitude D531 Coin Cell Battery Replacement, Loosen screw on memory module/coin-cell battery cover.: passo 2, imagem 1 %32
    • On the bottom of the computer, loosen the captive screw on the memory module/coin-cell battery cover and remove the cover (see image).
  2. Dell Latitude D531 Coin Cell Battery Replacement, Use scribe to lift up coin-cell battery; replace battery.: passo 3, imagem 1 %32
    • Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and ease the battery out of the compartment.
    • When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
    • Tighten the screw on memory module/coin-cell battery cover.
    • Install the battery.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 119
