Ir para o conteúdo principal
Dell Latitude D530 Screen Replacement
O que você precisa
  1. Dell Latitude D530 Screen Replacement, Screen: passo 1, imagem 1 %32 Dell Latitude D530 Screen Replacement, Screen: passo 1, imagem 2 %32 Dell Latitude D530 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove the 4 small circle dots from the borders of the laptop screen. Simply pull the dots out of their sockets.
    • Also remove the one longer rubber piece from the top of the screen. Simply peel the rubber piece from its place.
  2. Dell Latitude D530 Screen Replacement: passo 2, imagem 1 %32 Dell Latitude D530 Screen Replacement: passo 2, imagem 2 %32 Dell Latitude D530 Screen Replacement: passo 2, imagem 3 %32
    • Unscrew and remove the 6 6mm screws that were under the rubber pieces using a Phillips #1.
    • If the screws will not come out easily, use the magnetic bit to remove the screws all illustrated.
  3. Dell Latitude D530 Screen Replacement: passo 3, imagem 1 %32 Dell Latitude D530 Screen Replacement: passo 3, imagem 2 %32 Dell Latitude D530 Screen Replacement: passo 3, imagem 3 %32
    • Use the spudger to pry the plastic border off.
    • Be sure that the plastic notch at the bottom of the screen is pulled out correctly. Pull the border to the left of the screen and out.
  4. Dell Latitude D530 Screen Replacement: passo 4, imagem 1 %32
    • Unscrew the 8 6mm screws located on the outer border of the screen using a Phillips #1.
    • There are 4 screws on each side.
  5. Dell Latitude D530 Screen Replacement: passo 5, imagem 1 %32
    • Use the spudger to pry the screen up.
  6. Dell Latitude D530 Screen Replacement: passo 6, imagem 1 %32 Dell Latitude D530 Screen Replacement: passo 6, imagem 2 %32 Dell Latitude D530 Screen Replacement: passo 6, imagem 3 %32
    • Lift the screen up and fold over gently.
  7. Dell Latitude D530 Screen Replacement: passo 7, imagem 1 %32 Dell Latitude D530 Screen Replacement: passo 7, imagem 2 %32
    • Pull on the blue tag sticking out at the bottom of the screen and disconnect the wire.
  8. Dell Latitude D530 Screen Replacement: passo 8, imagem 1 %32 Dell Latitude D530 Screen Replacement: passo 8, imagem 2 %32 Dell Latitude D530 Screen Replacement: passo 8, imagem 3 %32
    • Towards the top of the screen on the back, unplug the “this side up” wire.
    • This can be done by squeezing the 2 metal side clips of the wire.
    • This could be difficult so wiggling the wire a little bit may be necessary.
Conclusão
Kyle Cabral
Membro desde: 03/19/18
604 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 844
